โMay-20-2022 01:03 PM
โMay-23-2022 06:28 AM
โMay-23-2022 06:23 AM
โMay-23-2022 05:41 AM
pianotuna wrote:
High draw on LiFePo4 is limited by the battery management system. It depends on what the maker sets it at. Anyone know what is most common? 100 amps (1c)???
Seeing as my goal is a battery bank of at least 400 and possibly 700 amp-hours, the speed of charging of Li is not useful to me--as my fastest charger maxes out at 127 amps @ nominal 12 volts.
Efficiency also does not concern me as I want to float the batteries between trips. SiO2 float nicely. Li, not so much.
For me, the most important factor is full charging not required on each cycle. My understanding is that both Li and SiO2 are quite happy, if they are fully recharged once every 30 days.
โMay-23-2022 05:30 AM
3 tons wrote:
StirCrazy said: โhaha, weird that they are so expensive there for LFP. you had to order the Sio2 and just doing a quick search a drop in bought online from alberta lithium is 550ish this one
but ya it makes sence if you alreay had one to get another , after all what are you going to do, throw it out.โ
โฆFor PT, cold weather is of paramount concern, so itโs great for others to know that thereโs a viable alternative that (admittedly here, just from my own perspectiveโฆ) has excellent performance characteristics though (IMOโฆ) seemingly more similar to other FLAโs (i.e. but higher currents, and no sulfating = longer life) than to the nearly flat voltage plateau of LFPโsโฆ
3 tons
โMay-22-2022 09:49 PM
โMay-22-2022 07:59 PM
โMay-22-2022 07:50 PM
BFL13 wrote:
High draw per capacity ability and higher charging efficiency are different things
LFP has both; SiO2 has the first, not so much
of the other AFAIK but will know when I plot a charging profile
โMay-22-2022 06:13 PM
โMay-22-2022 05:47 PM
โMay-22-2022 04:50 PM
โMay-22-2022 04:21 PM
โMay-22-2022 03:48 PM
โMay-22-2022 02:21 PM
BFL13 wrote:
I got the SiO2s in late 2020
Seldom used since with covid reducing dog events. Took the TC out myself the other day to see that it all still works now things are starting up again
โMay-22-2022 01:29 PM
โMay-22-2022 11:47 AM
