โOct-31-2017 09:42 AM
โNov-04-2017 12:26 PM
โNov-04-2017 10:07 AM
โNov-04-2017 09:49 AM
โNov-04-2017 09:42 AM
Mako Kupo wrote:
well I do have a few beams intact from before, but overtime I try to cut them, I bend my jigsaw blade and it messes the expensive wood up. a circular saw would actually work too? I'm concerned about being able to turn it, but I suppose it doesn't have to turn much does it. ill give it a try, thank you so so so much!
โNov-04-2017 07:34 AM
โOct-31-2017 11:59 PM
โOct-31-2017 06:28 PM
CJW8 wrote:
Keep it simple. Take a 2X4 long enough to span the walls. Lay it in it's side and draw an arch, starting on one end 2" from the bottom and ending on the other end 2" from the bottom where the top of the arch is the top of the 2X4 or 3.5". If you want more insulation or need room for duct work use a 2X6 and arch it so that it is 3" on the ends and 5.5" at the center. Cut the first one and use it as a pattern for the rest. Always use the same one as a pattern. The arch will be gradual enough you should be able to make the cuts with a skill saw.
โOct-31-2017 06:09 PM
โOct-31-2017 01:38 PM
โOct-31-2017 01:13 PM
โOct-31-2017 10:29 AM
โOct-31-2017 10:15 AM
โOct-31-2017 10:13 AM
โOct-31-2017 10:02 AM
