Slow/ No Cranking
Charley67
We have a new to us 2002 Winnebago Adventurer. It will usually start, but it turns over more slowly than it should. After driving a hundred miles or so, it will not even turn over until it cools down for about 30 minutes. I suspect the brushes in the starter are bad, but Iโ€™m hoping for some added insight. My battery shows 12.6 volts.
20 REPLIES 20
Lwiddis
On a 2002, Iโ€™d want a new starter regardless of the problem.
markchengr
I have experienced a starter on an older vehicle which bound up when hot due to worn bearings. It worked fine when cold. Just another possibility.
Charley67
Iโ€™ve pretty much checked the cables. I think Iโ€™m going to pull the starter relay and use a jumper wire to bypass everything. I think that will tell me if itโ€™s the starter or something back up the line. I had thought it might be the remote relay, but I believe they usually just make a single click sound if theyโ€™re bad
jkwilson
Charley67 wrote:
I have a battery boost that will connect my house batteries with the engine battery but it doesnโ€™t help. Iโ€™ve also tried jumper cables.
Usually when boosting doesnโ€™t help, itโ€™s the starter or cables.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
Charley67
jkwilson
12.6V is on the low side. A load test would be useful. Does jumping or using a boost charger on it help speed up the cranking?
John & Kathy
