โApr-01-2015 09:18 AM
โApr-04-2015 03:13 PM
christopherglenn wrote:
I loosened the screws holding the skin on, gently pried it down 1/4 inch, and fed a wire fish under the skin. There is insulation between the skin and floor along with frame parts. Once I had the gap for the airline, I pushed it in from the generator compartment to the pinbox, then routed the excess across the generator compartment and to the side compartment. The compressor and tank along with valves are in the side compartment under the batteries.
โApr-03-2015 05:21 PM
โApr-02-2015 03:49 PM
I ran truck airbrake tubing from the pinbox to the side storage compartment. I have a Viair with a 0.5 gallon tank there. And manual valves to fill and dump the pinbox. The Viair is on a 140 psi pressure switch, and has an air fitting for extension airlines / tools. I use it to fill tires as well.
I replaces the Schrader valve on the airbag with a Tee fitting, put the factory Schrader on the front (as a manual fill if the compressor dies) and the airbrake line off the rear.
โApr-02-2015 09:24 AM
โApr-02-2015 04:25 AM
Boxer Lovers wrote:
How much p.s.I. can it produce? My Triglide needs up to 95 p.s.I. to come to level. I have to use a 150 p.s.i. pancake compressor to inflate. Small compressor will allow pressure to escape the air bag.
โApr-02-2015 04:11 AM
โApr-02-2015 03:58 AM
โApr-01-2015 09:48 PM
โApr-01-2015 09:43 PM
โApr-01-2015 09:31 PM
โApr-01-2015 09:20 PM
โApr-01-2015 09:16 PM
โApr-01-2015 08:55 PM
