โJan-09-2020 06:02 AM
โJan-10-2020 03:22 PM
โJan-10-2020 03:13 PM
Osiris wrote:pianotuna wrote:
Add solar at 15 watts per 100 amp-hours of storage. Use a small charge controller.
Can you link an example of such a solar panel?
โJan-10-2020 02:23 PM
โJan-10-2020 12:20 PM
โJan-10-2020 12:18 PM
Osiris wrote:MrWizard wrote:
To the OP
You said inverter
Do you mean converter for charging the batteries
Or possibly
Inverter charger Combo, charges battery when generator is on,
Makes 120v when the generator is off
yes, inverter/charger combo. It doesn't do anything when generator is off.
โJan-10-2020 12:17 PM
Osiris wrote:
I have a large battery inside which is dedicated to a winch. That is the battery i am most concerned about keeping charged.
โJan-10-2020 09:53 AM
2oldman wrote:Osiris wrote:Why are we concerned about running this and the charger at the same time?
The scenario is essentially the trailer may sit for long periods of time with no shore or generator power. During these intervals, i'd like some type of solar trickle charge..
โJan-10-2020 09:51 AM
โJan-10-2020 09:17 AM
BFL13 wrote:
Scenario is very unclear. Not an RV. The car hauler trailer does need a battery for its emergency breakaway brake system (by Law) so "the battery" might be just for that.
No idea what the rest of the scenario is, and so no idea what equipment is needed. Eg, is the tow vehicle with a slide- in camper as the RV part, so you use the camper at events the car is for? Whatever, you get better answers to your questions if we know the scenario.
Back to the original OP question, that PowerMax converter is the nifty LK model, so it has adjustable voltage. So you can get any old solar controller with no adjustable voltage, measure what voltage it does, and match that with the LK. If you actually need to or want to.
time2roll wrote:
Not as long as you are parked. Rolling down the road the 7-pin connector will connect the tow vehicle charging system. Just saying this will not present an issue either.
โJan-10-2020 08:32 AM
Osiris wrote:Not as long as you are parked. Rolling down the road the 7-pin connector will connect the tow vehicle charging system. Just saying this will not present an issue either.time2roll wrote:
Multiple charging sources are not an issue. You can run all at the same time plus run down the road with your alternator charging. No issues, none.
Its a car/toy hauler, so an alternator is not part of the equation.
โJan-10-2020 08:29 AM
TechWriter wrote:OK very good. With updated solar programming and replacing the faulty batteries all is operating good together.time2roll wrote:
I did not see a resolution. Did you get this corrected? The responders seemed to imply there were programming adjustments to be made on the solar controller.
The solution is in my last post in that thread.
โJan-10-2020 07:52 AM
โJan-10-2020 07:31 AM
โJan-10-2020 07:10 AM
2oldman wrote:Osiris wrote:For how long?
the 7 watt is only to maintain the level the battery is at.
