โApr-01-2016 07:26 PM
โApr-02-2016 02:56 PM
โApr-02-2016 02:23 PM
Eco is missing on this Abs stage, you can set it 14,8 (or whatever it says in battery manual), but it lasts mere seconds unless you are watching it and changing settings on the controller manually. This is one of the things that I don't like about it, and there are few others. But you won't find anything both cheaper and better.
15A Morningstar model will exceed the limit occasionally , though unlikely will go up in smoke unless you are at high elevations. It might, but not likely.
โApr-02-2016 02:16 PM
โApr-02-2016 01:36 PM
lawrosa wrote:
I am looking to do this on the cheap.
โApr-02-2016 01:15 PM
lawrosa wrote:
Im going to set it up on a stand and move it around to follow the sun..
lawrosa wrote:
The morningstar looks nice but is only a 15 amp model while that chinese unit is 20 amps..
lawrosa wrote:
Are there any other models to consider?
โApr-02-2016 12:40 PM
โApr-02-2016 12:37 PM
โApr-02-2016 11:43 AM
westend wrote:The morning star is 154 while the eco is 110 on amazon..
Get the Morningstar, it will be the best $44 you spend on the system.
BTW, that is the lowest price I've seen on the small Morningstar MPPT controller. I paid $200 for mine.
โApr-02-2016 11:37 AM
โApr-02-2016 10:28 AM
โApr-02-2016 09:36 AM
โApr-02-2016 09:11 AM
โApr-02-2016 08:20 AM
โApr-02-2016 08:14 AM
JiminDenver wrote:Good information. 250/14.8 = 16.9A for bulk flooded battery charging. No reason IMHO to consider amps at 12.0V.
The max I have seen from my 250w panels is 18.5a on MPPT. On PWM they will put out 10+ amp at altitudes we camp at.
โApr-02-2016 07:36 AM
