Solar panels is this a good price?
NinerBikes
240Watt solar panel at Solar Blvd
$0.79 per watt, look at the spec sheet for amps.
5 REPLIES 5
NinerBikes
SCVJeff wrote:
Should i bring my ladder and a drill over?
No, but you can bring good microbrew beer instead, and supervise! What I'd really like is one of those fancy High $$$$ LiFePo 100 AH batteries, but with the stock market in the toilet, and oil prices so cheap, I'm not feeling comfortable about getting full use until death out of it, or 2000 charge cycles. Hella lot of money for hella little powerful battery.
What's a barrel of oil at today? Under $50 for Cushing West Texas Intermediate?
I put this post up for potential solar panel buyers that are frugal... BTW what ever happened to Mena661 and his project?
The 150W poly panel I have now portable is pretty much all I need for now, probably for the future too, after putting in all LED's for lights and picking up a little 24" Samsung TV that pulls 19W, or under 2 amps when running.
JiminDenver
They have the Amerisolar 250w for $170 or .68 a watt. One of those and a new and improved Eco-worthy 20a MPPT for $100 or less makes a nice starter system good for a peak of around 18a.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
SCVJeff
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
time2roll
Especially good deal in so cal to just pick them up.
Shipping the large panels can be a bit much.
MrWizard
Moderator
Moderator
depends ?
you are going to need a 20 amp mppt controller to use that panel
6.76 power point amps at 30.2v .. will produce about 15 amps at 14v converted with mppt
and is waste of power and money if you don't use mppt
got to look at the whole picture
it is a good price per watt, IF you are figuring on going mppt
I can explain it to you.
1997 F53 Bounder 36s
