Start/Stop Harness to Generator Connections
chinookjfs
I purchased a used camper set up with a Gen Prep that was never used I checked and it has everything Start/Stop switch, Harness, Transfer Switch, SafeGuard Overcurrent Protector etc.
I also purchased a used Onan 5500 Generator and am installing it in my camper but need help with the start stop wire connections to make sure they match up. If possible can someone take a look and see what wire contact changes I may need to make so that the existing harness fits the Onan Generator.
Have attempted to attach photos ???
Thank You
2 REPLIES 2
Dakota98
Go HERE drag, drop, copy & paste into your post.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
j-d
Post Model Number and Spec Code. Somebody here can find you a Shop Manual with Wiring Diagram. I bought a used ONAN and needed the connector from coach wiring to generator's remote control connector. Local Cummins/ONAN distributor had it in stock, and that was for an older generator.
You can't post photos directly to this Forum. They need to be on a photo site, your personal webpage, or even most advertisements will post.
Once the photo's up, enter Advanced Post Form right by the Quick Reply box here. Then the yellow "post card" Paste the photo's web "Properties" into the dialog box, max width 480, and it should be visible here.
When you EDIT a post you've already made, you're put into Advanced Post Form automatically.
