โAug-21-2018 12:36 PM
โAug-23-2018 05:18 PM
โAug-23-2018 03:00 PM
bpounds wrote:Yes, the Morningstar MSView software logs and creates a CSV file and the rest is done in Excel.
I'm impressed with the time you guys put into your spreadsheets. I assume you pull that out of your Morningstar charge controllers.
โAug-23-2018 01:51 PM
โAug-23-2018 11:32 AM
โAug-23-2018 08:55 AM
โAug-23-2018 08:50 AM
โAug-23-2018 08:40 AM
bpounds wrote:Other than panels there is almost nothing in common between grid tied and RV solar so I'm not going down that route.
I think a load tester would do it, sort of. I won't do that. The inverter load would be the closest thing to a designed in tester.
Clearly what I was asking about is not practical on an off-grid system.
Consider a grid-tied solar system. That array is going to be putting out full capability, based on available sun load, at all times. What power your home is not consuming will feed the grid. You can look at that inverter monitor at any time and see the full capacity at that moment. The grid is like a battery that is always hungry, never fully charged. The panels are always harvesting all the sun available, and that can be monitored. Cannot do that off-grid.
โAug-23-2018 08:25 AM
.... Cannot do that off-grid.
โAug-22-2018 08:30 PM
โAug-22-2018 07:11 PM
โAug-22-2018 06:54 PM
BFL13 wrote:
You compared the 14 with the 40 and your controller is a 40 amper. So it was not volts! Morning battery voltage (no charging) would be 12.x, rising during the day to 14.x with solar charging.
โAug-22-2018 06:42 PM
โAug-22-2018 06:41 PM
pianotuna wrote:
Hi,
All I see is a blank sheet.Itinerant1 wrote:
Here are recordings from last years all boondocking 24/7/365, note I have Lifepo4 batteries so they charge quicker with extra power going to rv fridge or other 120v items through the inverter.If you're interested.
2017 PV system/ boondocking
โAug-22-2018 06:31 PM
