The Best Quality 200-Amp Solenoid I Have Yet Seen
MEXICOWANDERER
TROMBETTA
https://www.ebay.com/itm/Trombetta-12-Volt-4-Terminal-Solenoid-200-AMP-Continuous-Duty-114-1211-020/...
Trombetta seems to be using better materials and design for its electromagnet. Significantly stronger pull-in for the number of amps used to maintain full contact pull-in.
Just for curiosity's sake...
Stronger spring for fast release. Less arcing.
The maintain coil amperage is less than 2.0
15 REPLIES 15
GordonThree
Sure looks heavy duty. Is it legit on the inside, did you cut one open?
Interesting ... according to the Trombetta website, their relays are made in USA and Mexico, so why re-import one from China? It's either a counterfeit or something else fishy going on?
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
