โJul-01-2019 07:38 AM
โJul-11-2019 10:07 PM
โJul-11-2019 06:28 PM
โJul-11-2019 11:15 AM
โJul-10-2019 10:29 AM
โJul-10-2019 02:53 AM
โJul-09-2019 08:50 PM
โJul-09-2019 03:30 PM
โJul-09-2019 08:02 AM
โJul-09-2019 07:46 AM
ernie1 wrote:
I want to state this again and for the last time. The refer works fine and as it should on ac and as expected on 12v. BUT not very well on propane at all. So my thought is that the installation is proper otherwise it would not cool properly on ac. It is just the propane setting that won't cool properly. Again, my 2 friends have an identical refer and one also has a Dometic but a smaller model and we have the identical problem. So something is wrong that is common to these Dometics. Also I might as well say it loud and clear now, Dometic as a manufacturer is not worth a darn and has failed to correct this problem. Dougrainer, with your 40+ years of experience I feel you can do better than tell me that the chances of the wrong sized jets being installed on all three of these refrigerators aren't logical and that Dometic is blameless. What I expected from you was what the problem with these refers are. If the refers work fine on ac and 12v but not well on propane why is it a faulty installation? These are brand new units and Dometic via repair shops has been diddling with them to a point where they gave up and told the owners that the refers were operating as expected. Come on Doug you can do better.
โJul-09-2019 06:58 AM
โJul-08-2019 10:08 PM
ernie1 wrote:
NRALIFR My refer has two side vents and I've installed two 12v fans behind the top vent and when the fans are running I've actually noticed the refer losing ground and the inside warm up a degree or two so now I've quit running the fans totally. You're right about reading the installation manual and I will but I'm still saying if the installation was not proper, why does the unit run fine on ac and 12v BUT not propane. Also, My two friends with Dometics of the same vintage complain about the same issue. Logic is clear to me in this case that there is something not right with the propane part of these refers. I'm tired of hearing about how blameless Dometic is and when I reach out for help to their tech people they are clueless, rude and condescending. At this point I think I'm beating a dead horse in trying to find a solution and getting wound up in company loyalty issues etc rather than dealing with facts.
โJul-08-2019 08:49 PM
โJul-08-2019 08:30 PM
โJul-08-2019 11:33 AM
dougrainer wrote:JRscooby wrote:dougrainer wrote:
Also, Are any of you or your friends refer installed in a slide room? THAT is also a different situation that usually calls for a separate exhaust fan blowing out the top door. Doug
I can not disagree with this, but just for my understanding, could you tell me why this is true?
Simple. The normal install for a RV refer is to have the cold air come in thru the bottom outside door and convection the air thru the condenser and up and out the roof vent. Normal convection air gets this done. Larger RV refers need an addition fan to help blow the air up and out, which the refer maker installs if needed. Now, when you have the refer in a slide out, the air flow IS going up, but must make a 90 degree turn and out the upper vent door since you do not have a roof vent in a slide room. Most OEM's do a poor job of making the upper wood cabinet with the required wood baffles to help turn that air and out the upper door. So, a lot of the hot air stays caught behind the upper refer and allows poor ventilation and cooling. Sooo, what I do is modify the upper back of the cabinet to seal off any place that can trap air. I then add just 1 12 volt refer fan just inside that upper door blowing out to force the hot air out the upper door. Also, when you remove that upper door and you can see most ofthe condenser fins, that is also a problem. That is why it is critical to make sure you have a wood baffle as close to the back side of those fins to make sure the cooling air goes thru the condenser instead bypassing between the sidewall and the condenser. THIS is the most common OEM error on baffling the refer cabinet. Doug
