โJul-24-2013 03:50 PM
โJul-24-2013 04:49 PM
โJul-24-2013 04:22 PM
MEXICOWANDERER wrote:So in this case, you're saying that there could be more than 55 amps drawn on a 55 amp converter? If this is the case, then I finally understand.
What happens if the converter gets mad, and I mean really REALLY mad at you and throws a hissy fit? A direct short with 4AWG is awful, like battery exploding time. Yeah fuses are a pain but what they may protect against is infinitely worse. Remember, Kelly said Murphy was an optimist...
โJul-24-2013 04:21 PM
MNtundraRet wrote:A short could only draw max amps from the device or devices on that circuit right? Then wouldn't just having adequately sized wiring do the trick? The amp draw won't be forever, the device will fail eventually. I guess I'm just not getting this. I can see the point of a circuit breaker on a 120V circuit cause you can have many devices that can draw more than the wire rating. I can also see protecting inadequately sized wiring (which is common in RV's). But if I have big honking wire, it's not going to melt with a current draw under it's rating. At least I don't think it would but that's why I'm asking.
The fuse is protecting from shorts on a circuit. Worn or cut insulation on a cable. A loose connection sparking.
โJul-24-2013 04:15 PM
Francesca Knowles wrote:That very well could be the case but I'm told different. Hopefully someone will weigh in on this.
I always thought fuses protected everything on the circuit, not just the wiring.
โJul-24-2013 03:54 PM
