โJan-19-2018 10:38 AM
โJan-21-2018 12:34 PM
โJan-21-2018 11:56 AM
โJan-21-2018 10:45 AM
SoundGuy wrote:
'Though I'm sure unintentional you're supporting my argument that for some a 100 watt system can serve their needs just fine.
โJan-21-2018 07:16 AM
โJan-21-2018 05:45 AM
MrWizard wrote:
i run the generator for breakfast and morning charge routine
i figure 200w will maintain charge status and power my laptop,
so the batteries are still charged come evening
just run genny for supper
โJan-21-2018 05:20 AM
SoundGuy wrote:
... there are some here on the forum who for their particular needs manage just fine with a single G31 battery and 100 watts of solar.
Almot wrote:
100W solar will harvest ~30AH on a good day.
I often use under 35AH a day.
โJan-21-2018 03:08 AM
DAS26miles wrote:You will not gain much on a 12 volt panel configuration. MPPT's big advantage is using panels that are higher volts. This can be accomplished by using a panel that is 24 volts or higher or connecting panels in series. If panels are connected in series, they must have similar current ratings. If connected in parallel, they must have similar voltage ratings. The portable unit mentioned previously has panels that can not be easily reconfigured.
My controller is the the 30amp Renogy Adventurer. I may upgrade to a MTTP depending on how much more amps I can get out of the existing panels.
โJan-20-2018 01:36 PM
โJan-20-2018 01:13 PM
โJan-20-2018 01:02 PM
Almot wrote:
There is not much harvest from 100W portable, you can't live on this source alone.
There is more harvest from 200W portable, but this is more panels to handle and it's still tough living on 200W even when tilted - doable but not always.
โJan-20-2018 12:58 PM
โJan-20-2018 12:14 PM
โJan-20-2018 04:48 AM
DAS26miles wrote:
The 200 watt portable probably can't be tapped into my system as the voltage is only 18 volts and my Renogy system is 20 volts.
โJan-20-2018 04:43 AM
โJan-20-2018 04:22 AM
Tom_M wrote:DAS26miles wrote:The Dokio 200 watt mentioned consists of four 50 watt panels connected in parallel. This has a Voc of 22.5 volts which is typical of a 12 volt panel. If your existing panel is 12 volt you can parallel this panel with yours if your existing controller can handle the added current. Or you could use this panel and controller and connect directly to your batteries using the included battery clamps.
I have disconnected the controller on the Renogy suitcase and use the existing wiring and Anderson connector. I added an Anderson connection mounted near my batteries and controller for the roof mounted panels. Now easily able to attach portable directly into wiring before controller with disconnect switch.
