May-06-2013 07:31 PM
May-09-2013 07:19 AM
MEXICOWANDERER wrote:
Here is an image of a LEVITON which also should do the job. Select your button.
May-08-2013 01:57 PM
May-08-2013 01:46 PM
May-08-2013 09:00 AM
May-07-2013 04:40 PM
camperpaul wrote:Dutch_12078 wrote:
I don't know just how long you want the fan to run, but this typw of mechanical switch should work:
GE 15-minute Auto Shut-Off Switch
First the disclaimer:
In the 1980s, I worked for Intermatic as the Chief Electronics Mfg Engineer and Chief Test Engineer.
That GE timer is almost identical to the clock-spring timers made by Intermatic. They are available in various versions with different run-times, from 5 to 60 minutes.
Because they do not require electrical power to operate they are perfect for your application.
They can be used for switching any voltage from 6 to 240 Volts AC or DC. The contacts are rated for 15 Amps incandescent, which means they will safely handle the 200 Amp inrush of a 300 Watt heat lamp.
May-07-2013 04:12 PM
May-06-2013 08:17 PM
May-06-2013 08:12 PM
May-06-2013 07:45 PM
May-06-2013 07:39 PM
