Toilet
Eagle1951
How do you keep water from coming out from under seat while flushing. It does it when on pump or city water. Have not seen a pressure value to turn pressure down.
Thanks,
9 REPLIES 9
Home_Skillet
I have a Thetford like the OP.
The water enters the top left of the bowl at the top rim, then swirls around counter clockwise into the bowl.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
Robin1953
Home Skillet wrote:
Swap the toilet.
Poor design by Thetford.
Sounds more like a Dometic 310/320 toilet. The holes under the seat in the rim spray everywhere.
2015 Grand Design Solitude 320X
2016 Ram 3500 DRW and Cummins
Dutch_12078
What make/model toilet is it?
Dutch
2001 GBM Landau 34' Class A
Muddydogs
My toilet does this to. If I don't at least put the seat down it makes a big mess, with seat down some water is contained but not all.
2015 Eclipse Iconic Toy Hauler made by Eclipse Manufacturing which is a pile of junk. If you want to know more just ask and I'll tell you about cracked frames, loose tin, walls falling off, bad holding tanks and very poor customer service.
RJsfishin
Whats the model # ? I never had that prob w/ any of them.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
1492
Moderator
Moderator
Moved from Forum Technical Support
edbehnke
dometic 320 is the answer
eddie and sandie
3402 Montana 2013
Ford F350 2015
ScottG
Get an in-line valve for the water line and restrict the flow just enough to keep this from happening.
I put one on mine just to keep it from using too much water when we're dry camping. (my SeaLand is a water hog!)
Home_Skillet
Swap the toilet.
