โFeb-05-2017 03:31 PM
โFeb-09-2017 04:36 PM
โFeb-09-2017 04:28 PM
Searching_Ut wrote:
I too really like the Trimetric and SC2030 solar charger combo, and have my finish voltage and overcharge setup virtually identical to Grizzzmans. My solar componentry changed a couple times last year, as I tried a couple different borrowed MPPT controllers, and both series and parallel variations on the panels. I also grew the system from 400 to 600 Watts. I definitely prefer the SC2030 controller overall, with the panels of course in Parallel. It does a better job of charging the batts than anything else I tried. As mentioned, it doesn't work with the high voltage panels, but being I prefer parallel panels scattered across as much of the roof as possible, it seems to be the best compromise for the mixed shade we encounter in many of the areas we like camping in.
I have 4 additional 100 watt panels in the garage, and all the other items I need to upgrade my solar to 1000 watts total when the weather improves, 10 panels in two banks of 500 watts. The trimetric can control 2 SC2030s with a simple jumper harness connected between the controllers. Ralph at Bogart engineering helped me get me set up for the upgrade.
โFeb-09-2017 04:06 PM
โFeb-09-2017 02:49 PM
โFeb-09-2017 01:22 PM
grizzzman wrote:
Additionally when my system hits its amps setpoint the amps are maintained and the voltage is allowed to rise to 15.3 volts. A "finish" charge if you will.
โFeb-09-2017 04:53 AM
โFeb-09-2017 04:32 AM
BFL13 wrote:
My trouble with all that is I do not accept that the battery is truly full while it is still accepting amps such as 1 or 2 % of rated AH.
I know some battery blurbs use that notion and the Trimetric is just following that notion.
If you let the battery rest for a time after that, giving time for "SG Lag" to catch up, the hydrometer shows SG is not back up to "baseline." You can need an overcharge to get the SG all the way up, which shows that the battery was not fully charged.
On solar I have often seen the batteries finally reach baseline SG but the Trimetric is showing 10 or so AH "over" what was drawn down. That is despite the Tri's allowance for heat loss. You can adjust that allowance so it comes out even. The usual idea is you need to replace about 115% of what you took out.
IMO, relying on the Tri's notion of "full" is going to mean undercharging the batteries and some sulfation building up over time.
It may not work for others, but I prefer to decide when the batteries are truly at 100% myself, and only then to re-set the Trimetric AH counter.
This can mean operating for many days before solar conditions are good enough to get the batteries that high while you are camping and using the batteries. You have to limit usage and run the 12v stuff on "extra " solar while the batteries get that last bit of recharge, so the batteries do not have a draw cancelling the recharging amps, which is the case when there is no extra solar.
โFeb-08-2017 09:09 PM
โFeb-08-2017 07:27 PM
โFeb-08-2017 05:16 PM
โFeb-08-2017 04:22 PM
โFeb-08-2017 10:05 AM
โFeb-06-2017 10:21 AM
โFeb-06-2017 06:50 AM
โFeb-05-2017 04:51 PM
