Tripped Breaker
PaulnAnn
Hello, we had our fireplace spark last night and blow the breaker while just sitting here on our laptops.
I turned the fireplace off and tried the breaker again but it just 'trips' when I turn it on. It seems there's a short somewhere although we were just sitting here. Nothing different. If it was just we had our laptops plugged into the outlets and it was too much draw and tripped the breaker it should at least come on but it doesn't, even when I have the fireplace turned off and nothing plugged into the outlets anymore.
Weird part also is the breaker that tripped is marked 'general'. I'm not sure what that means!? As the breaker for the fireplace is a different breaker.
Any thoughts what I could do to diagnose the issue?
https://prnt.sc/32TMSgEOk_0Z
Thank you,
Paul (Ann)
We look forward to meeting other like-minded people. We would love to travel and work from our RV. Hoping to make this happen one day.
Our Rig:
2011 Ford F250 Diesel 4x4
2012 5Th Wheel Alpine 3600RS
7 REPLIES 7
Grit_dog
Navigator
Navigator
Yes very possible the FP is wired to the other breaker labeled general. In fact From what you describe Id say itโ€™s definitely wired to the general labeled breaker.
How many wires are coming into the general breaker? A bunch?
Also trip the FP breaker and see what doesnโ€™t work.
(Have you actually opened up the panel and see a wire to the FP breaker?)
If you arenโ€™t very familiar with residential electrical, youโ€™d be surprised what you might find out, depending on how hungover the electrician was that dayโ€ฆ.lol
MrWizard
Moderator
Moderator
As suggested labels might not be correct, unplug from shore power, and try to reset the breaker,
I know if i designed the wiring, i would have fireplace and A/C on the same breaker,
Because i would only use (1) or the other not both,
Find the power cord connection for the fireplace and unplug/disconnect it,
Once you figure out what circuits power outlets, fireplace etc..
Relabel things correctly
I can explain it to you.
1997 F53 Bounder 36s
CA_Traveler
What else doesn't work when general is tripped? Be sure to test every plug. The fireplace could be an option and hence on the general CB.
Labels may not be accurate. Suggest checking all marked CBs to verify their label. Turn off the 2 left CBs one at a time, what doesn't work?
The fireplace problem could be a plug or a positive short before the switch. Investigate.
2014 Grand Cherokee Overland
Bob
PaulnAnn
wa8yxm wrote:
You said the Fireplace sparked.. That is what is called a MAJOR CLUE.
What CA Travler said. Disconnect.
Note if the Fire place is a plug in model.. Check the outlet it's plugged into. A 1500 watt heater (Many electric fireplaces are) can melt the 15 amp "uni-box" or "Quick box" type rather easily.
I"m sure the fireplace has something to do with it since it sparked. My confusion is the breaker that tripped is called 'general' (see pic in original post) and not the fireplace breaker that's tripped.
I will try that but I'm trying to find out what the 'general' breaker is for.
Thank you
Our Rig:
CA_Traveler
If so run a new circuit and box from your left hand CB which can be a dual CB if it's a single. I suspect "general" means multiple plugs... ๐Ÿ˜ž OK for light loads - heaters not so much...
Bob
wa8yxm
CA_Traveler
Sounds like a fireplace short. Disconnect the wires to be sure. General could be the plug circuit or something in "general".
Bob
