Jun-04-2022 02:28 PM
Jun-05-2022 05:37 PM
Jun-05-2022 02:01 PM
Jun-05-2022 08:46 AM
Jun-05-2022 07:58 AM
wa8yxm wrote:
You said the Fireplace sparked.. That is what is called a MAJOR CLUE.
What CA Travler said. Disconnect.
Note if the Fire place is a plug in model.. Check the outlet it's plugged into. A 1500 watt heater (Many electric fireplaces are) can melt the 15 amp "uni-box" or "Quick box" type rather easily.
Jun-05-2022 07:49 AM
wa8yxm wrote:If so run a new circuit and box from your left hand CB which can be a dual CB if it's a single. I suspect "general" means multiple plugs... 😞 OK for light loads - heaters not so much...
Jun-05-2022 07:40 AM
Jun-04-2022 03:57 PM
