Mar-30-2019 05:30 PM
Mar-31-2019 09:35 AM
Mar-31-2019 09:25 AM
Mar-31-2019 08:29 AM
Mar-31-2019 08:25 AM
Mar-31-2019 08:04 AM
Mar-31-2019 07:01 AM
wa8yxm wrote:
Yes and no on the surge protector comment.
the hughes has MOV's (Spike suppressors) in it. these are what are sold as "Surge Suppressors" in many stores (The six outlet strip type) but are a long way from what I call a Surge Suppressor.
Mar-31-2019 05:44 AM
3 tons wrote:
FWIW I should note too that the Hughes Autoformer also doubles as a surge protector...
As to my above scenario, it appears to act as a buffer between the load and the power source...JMO
3 tons
Mar-30-2019 09:47 PM
Mar-30-2019 09:17 PM
Mar-30-2019 08:40 PM
pianotuna wrote:
Any chance of you using two meters to monitor the voltage before and after the autoformer?
My generator is a bit larger at 2800 watts (Yamaha sIEB), and will start the roof air in eco mode--but voltage tumbles way way down (about 90 volts). I've successfully used the Magnum in load support to help with starting--but it does cause the red "fault" light to come on. I do have the microair added to the roof air.
I'll have to try using the Sola Basic autoformer between the generator and the RV.
Mar-30-2019 08:23 PM
Mar-30-2019 06:38 PM
Mar-30-2019 06:22 PM
