โNov-12-2019 11:05 AM
โNov-27-2019 02:53 AM
โNov-26-2019 04:43 PM
rk911 wrote:
thanks. please update your report in a few months once you've had it up and down several times.
โNov-13-2019 04:42 PM
โNov-13-2019 11:51 AM
โNov-13-2019 11:29 AM
โNov-12-2019 06:21 PM
Ed_Gee wrote:
Since most digital TV stations have been moved to the UHF spectrum, and assuming you are not too distant from stations, that antenna should work well.
โNov-12-2019 04:00 PM
โNov-12-2019 03:57 PM
George3037 wrote:
The antenna in question will work without the net (reflector) but not as well as with it. I'd say assemble it with the net as they are very light and don't have much wind resistance. I have two similar OAT antennas with reflectors. One for use with my camper and one on top of the garage on a 10' pole. Been up there for past 3 years without wind problems.
โNov-12-2019 03:39 PM
BFL13 wrote:
It works! ๐
I have not figured out how to use this with my RV exactly so it does not blow away going down the road at 60 mph. That was one reason to ask about the "net" windage. It looks like there are a couple of ways--worry about that later.
โNov-12-2019 03:00 PM
BFL13 wrote:
Got one of these:
https://www.princessauto.com/en/search?Dy=1&Nty=1&Ntt=outdoor+HDTV+antenna
Can I do without the big "net" and the long VHF dipoles and still get OTA digital TV with the shorter UHF dipoles? I want to do without the "net" to reduce wind problems.
Thanks.
(The "net" as they call it seems to be a reflector like with WW2 British gunnery radars that had Yagis poking out of them.)
https://maritime.org/doc/br224/img/dia33.jpg
โNov-12-2019 02:43 PM
โNov-12-2019 02:32 PM
โNov-12-2019 01:48 PM
Yes, but can I do without the "net"?
BTW this antenna has a neat feature, which is why I got it. It rotates with the power for that also coming up the coax along with the usual amplification power.
โNov-12-2019 12:51 PM
