โOct-31-2022 11:04 AM
โNov-01-2022 09:23 AM
โNov-01-2022 09:07 AM
Cptnvideo wrote:
Typing while you posted, CA. Oops.
With the load sharing on each line, I will be able to run 18 amps worth of "stuff" on 15 amps of shore and not have to worry about tripping a breaker inside a friend/relatives home. Which to me is a little embarrassing.
โNov-01-2022 08:46 AM
โNov-01-2022 08:37 AM
โNov-01-2022 08:32 AM
Cptnvideo wrote:OK I didn't even consider that you would connect both inverters to one hot considering that you wanted to monitor each hot line with the inverter display.
Good points, wa8. I'm thinking about replacing the 3000 watt inverter/charger with 2 2000 watt units. Then using L1 of each so that I have monitoring and load sharing of both L1 and L2.
โNov-01-2022 08:30 AM
โNov-01-2022 08:28 AM
โNov-01-2022 08:18 AM
โNov-01-2022 03:21 AM
Cptnvideo wrote:
Nice post, wa8yxm. But doesn't really answer my question. BTW, neither did GoPower tech support.
Since I don't have any 240 VAC appliances, I don't see why I couldn't have 2 separate inverters and no need to sync them.
โOct-31-2022 04:48 PM
โOct-31-2022 04:16 PM
โOct-31-2022 04:14 PM
โOct-31-2022 04:01 PM
โOct-31-2022 03:41 PM
Michelle.S wrote:X2
Simple, install a good EMS that has a remote display of both legs L1 & L2.
I have the Progressive Hardwired EMS and know exactly what the voltage and current are on each leg.
โOct-31-2022 03:33 PM
