โApr-08-2016 10:17 AM
โApr-10-2016 07:58 PM
โApr-09-2016 09:28 PM
โApr-09-2016 08:43 PM
โApr-09-2016 08:32 AM
โApr-09-2016 06:57 AM
evy wrote:Almot wrote:
Not sure what you mean by "outside walls". Nobody covers exterior wall outside with wallpaper. There is normally a 1/4" interior plywood panel (covered with wallpaper), then 1.5-1.75" void filled with insulation, then exterior aluminum or fiberglass siding (or a steel sheet in motorhome).
I don't want to add wallpaper on the inside walls only the outside walls (not the outside of the wall) and also the ceiling, as you can see in the pictures as of now I only have plywood on the ceiling, I will be adding 3/8" plywood on the outside walls as soon as all the wiring and plumbing is done.
โApr-09-2016 06:29 AM
Daleg70 wrote:
Naio -- where would you buy the wallboard with wallpaper attached that you mentioned?
thx -- Dale
โApr-08-2016 08:49 PM
DrewE wrote:
For a simple and inexpensive and likely long-lasting (but not necessarily beautiful) finish, a good latex exterior house paint, on top of a decent primer, would be pretty good. I've heard of people painting wooden boats with such paint and getting good service, no worse than expensive marine boat paints.
โApr-08-2016 08:07 PM
โApr-08-2016 07:36 PM
Naio wrote:
Your plan looks great ๐
โApr-08-2016 07:35 PM
โApr-08-2016 07:25 PM
โApr-08-2016 06:45 PM
โApr-08-2016 06:27 PM
โApr-08-2016 06:03 PM
