Need to replace black tank extension rod. All replacements I see are threaded. Mine have a pin in it. Can’t find one that looks the same. Will the threaded one work? Thanks!
Valves normally have 1/4-20 threads. This unit appears to have threads on handle end and a set screw in the coupling. Valterra extension rod kit How much extension do you need?
