VideoHey gang,
First trip of the season this weekend. It was kind of last minute, so I only had three days to de-winterize, clean, and prep. When we fired up the water heater, this was what it started doing.
It runs for a few minutes like that, then quits. I thought it was a supply issue, but lighting the three burners and firing up the furnace has no effect on it whatsoever, and the tank is more than half full. Temps are in the upper 70s during the day, low 60s at night, so I don't think it's a pressure issue. I did find a cracked supply hose on one side of the switching regulator, but changing tanks made no difference whatsoever.
What could be causing it to puff like that? Orifice clog? Valve issue? I'm at a loss... I'll pull the burner tube out after breakfast, and can use the electric element in the mean time, but would appreciate some suggestions.
Thanks!
