Water pressure drop
m_roller
Hi everyone first post so hope itโ€™s in the right place. So I have a 2014 Mercedes spring class c and Iโ€™m having water pressure drop problems running off the pump but itโ€™s not consistent. I got a new pump even though I check and is was pumping 3 Gpm when I removed it from the camper and bench tested it. I put it back in and still wouldnโ€™t work just build pressure and instantly drop. So then I tried disconnecting the system from the tank and drew water from a bucket and it worked fine. So I hooked it back up to the tank thinking maybe the pump wasnโ€™t self priming like it says it should. And after I hooked it back up it work with the rv tank as a supply. I ran the water for 7 minutes with not drop in pressure. I thought the problem was fix so I took it out this weekend and it quiet working again. I have tried a few other things and sometimes it will work and then it doesnโ€™t very frustrating. So hopefully Iโ€™m missing something that someone else has had the same problem and can help cause I have to have it fix by this next weekend. Thanks for any advice.
5 REPLIES 5
QCMan
Nomad III
Nomad III
Is there enough water in the tank? That is the place to start because you can replace a lot of parts but without enough water in the fresh tank you will get just what you have.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
MFL
Nomad II
Nomad II
Description sounds like lack of tank venting.
Jerry
CA_Traveler
Leaky check valve allowing backflow into the tank.
2014 Grand Cherokee Overland
Bob
wa8yxm
You may have a tank vent issue (Clogged) or
Some tanks have an outlet strainer in addition to the pump inlet strainer. It can get clogged.
way2roll
Navigator
Navigator
Could be something as simple as sediment in the pump screen or the aerators on the faucets.
