Water pump not working on battery
chiefward
What would cause the water pump to work on shore power but not on battery? Battery charged to 12:8 volts. Fuse good. Any suggestions are appreciated.
2011 Fun Finder by Cruiser RV, model X210WBS
2017 Ram, 1500, Tradesman,
10,000 Equal-I-zer hitch
11 REPLIES 11
way2roll
Navigator II
Navigator II
chiefward wrote:
I am so redfaced Iโ€™m glowing. BB_TX you were right the switch was off..I just bought this trailer and still learning all itโ€™s ins and outs,,Iโ€™m definitely going to put a guard over this button. I thank all for your comments and suggestions. Wonโ€™t make this mistake again.
That was the very first reply. Glad you sorted it out.
Jeff - 2023 FR Sunseeker 2400B MBS
wa8yxm
Hey.. We all. even the best of us.. Screw up on occason.. Now I'm going to save you another face palm.
Complaint: Somethin is wrong with my water heater I only get warm water (or I get a burst of hot then only warm).
Queston: Have you used what I call the Dog Shower (Outside shower) recently?
ER Yes, what does that have to do with it?
Did you cut off the water flow at the head and leave the mixer valves open?
Face palm.. OPPS.
(True story by the way.. thankfully I was the guy with the answer.... that time)
BB_TX
It happens. If thatโ€™s the biggest mistake you make you will be doing great. Most of us have done worse at least once in our RV life. :B
chiefward
chiefward
Just checked and nothing works on battery. Not receiving 12volt power at fuse panel.. Replaced 30 amp inline fuse, no change. I have power at junction box under bed. Inspected wires from under bed to fuse panel, and no breaks on damage seen. Tomorrow Iโ€™m going to see if I can find some 8 gauge stranded copper wire to jump from under bed junction to fuse panel. I checked all connections at fuse panel and buss bar.
opnspaces
Navigator II
Navigator II
Are you saying the fuse is good because it visually looks good? Or did you put a volt meter on the fuse while it's plugged in?
If just a visual check you will need a meter to check to verify that there is 12 volts going in and out of the fuse.
At the fuse panel find good 12v positive and ground so you know your tests will be valid. Then leave the ground connected and move the positive lead to the water pump fuse and probe the back of the fuse while it is plugged into the panel and see if you have 12 volts. Probe both holes on the fuse and the meter should read the same. If you measure 12.63 volts on one hole you should also read 12.63 volts on the second hole.
If the readings are different replace the fuse. if both readings are zero you have no power going to the fuse.
If all fuses read zero find the reverse polarity fuses and check them.
bgum
Bad ground?
BB_TX
Do any of your 12 vdc devices work?
Is your battery disconnect switch turned to the disconnect position?
stickdog
Do other 12v items work on battery power when not hooked to 120v external power?
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
2oldman
Time for the voltmeter.
way2roll
Navigator II
Navigator II
Battery disconnect?
