Water pump pressure switch Q.
Almot
It should shut the pump off after I've shut the faucet off, as I understand. I think mine isn't working. Doesn't bother me much, as I'm always nearby and can flip the pump switch after I'm done.
Just curious. Waited a minute after shutting faucet off - pump still running. Didn't want to test it longer and overheat the pump. Model Flojet 03526144, flow 2.9 GPM, and in specs there is "pressure switch max 50 PSI".
4 REPLIES 4
Almot
Air in the line - possibly. Will check.
TakingThe5th
Did you pick up some air in the lines somehow? My pump won't shut off until the air is gone. Run all faucets and see if that helps.
TakingThe5th - Chicago, Western Suburbs
'05 Ford F350 Crew 6.0 DRW Bulletproofed. Pullrite Super 5th 18K 2100 hitch.
'13 Keystone Cougar 333MKS, Maxxfan 7500, Progressive EMS-HW50C, Grey Water System.
boogie_4wheel
downtheroad wrote:
It might take a minute or so to re-pressurize before the pump shuts itself off IF the system doesn't have a leak or if another faucet isn't open.
A literal minute? Mine loads up and shuts off in 2-4 seconds. Same with the horse trailer LQ.
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer,Transgo Shift Kit ISSPro Oil and LP pressure gauges, GDP 20/2 filters, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
downtheroad
Could mean that there is a break or small leak
somewhere in the system and it's not pressurizing.
How long did you wait after you closed the faucet?
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
