Water tank leak?
acritzer
Getting ready for the season...new prob. I seem to have a minor leak in my water tank, or in the tubing that leads to the tank (where it gets filled). After filling up I notice that there is dripping leak near the drain valve. Unfortunately it's not the valve. It seems to be traveling down the outside of the tank to the low point. Or it's from the actual process of filling.
I suspect that it's either high up on the tank or part of the plumbing because when the tank is half full or so it doesn't seem to leak.
Aside from pulling down all of the undercover to totally expose the tank, what are my options? Sound like something worth messing with?
7 REPLIES 7
treetopper
After purchasing, I used my 5th twice.
After parking from the second trip, I noticed the familiar coraplast 'bulge'.
Long and short I took the unit to the tech. He drained the water, it was fresh, i.e. no odor. He discovered a leak at the city water inlet. Tightened the fitting. No more leak. (Water was traveling to the lowest point).
Yeh, it was an expensive 'wow, that didn't take long'.
But he did inspect the mounting for all the tanks and took pictures for me.
2012 F350 DRW SUPER CAB
6.7L, 3.73 REAR END
5TH WHEEL HITCH PREP PKG
B&W Hitch
2013 338RLS
bob213
If it's a leak in the tank and not a hose try this stuff:
plastic repair
You'll have to have room to get a torch in there to warm it up a little. Watch the video in the link.
Hopefully i't just a hose connection.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
Boon_Docker
midnightsadie wrote:
look at the safetyy relief valve ,they are a known leak .
I think the OP is talking about the fresh water tank. No relief valve.
midnightsadie
brirene
Good luck! Here's hoping it's an easy fix.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
acritzer
I hear ya....just a daunting project to consider right now. The covering underneath would take a lot to detach.
Going to see if it has stopped in the morning. Use that to help determine if it's in the plumbing or the tank itself.
Thanks
brirene
If it were me i'd want to know where the leak is coming from. Might just be a loose clamp, but doubt it's going to fix itself. Whether from above our below, a water leak is not your friend.
