May-21-2019 09:08 PM
May-23-2019 08:33 AM
May-23-2019 08:08 AM
time2roll wrote:jbfoster wrote:My small, light, compact and low noise 700 watt propane generator will easily put 20 amps into a 12v battery.
I was going to get a 1000 watt generator but I am now getting a 1800 watt generator. It's rated at 15amps so I don't want to use a charger more than 10amps.
Check Ryobi at Home Depot.
May-23-2019 08:00 AM
May-23-2019 07:54 AM
May-23-2019 07:02 AM
May-23-2019 12:21 AM
jbfoster wrote:
I was going to get a 1000 watt generator but I am now getting a 1800 watt generator. It's rated at 15amps so I don't want to use a charger more than 10amps. I don't have an RV. We will be tent camping for a while.
Thank You
Jim
May-22-2019 11:15 PM
MrWizard wrote:
you have the use time figured correctly
however it 'ALWAYS' takes more energy than what was used to replace the used wattage aka ampHrs and its not linear
it won't be 10amps for 5 hours, it will start out higher amps and decrease/get less the closer the battery gets to being fully charged
the reversing of the chemical reaction that makes electricity uses power while doing the conversion/restoration
thats why you want a 30-45 amp charger
it will start out high and go down,
you will get charged faster
a 10amp charger will take 7 to 12 hrs to get too full charge
replacing 50 ampHrs
it will start at 10 and go down, making for a long charge cycle
May-22-2019 10:25 PM
May-22-2019 10:13 PM
May-22-2019 08:34 AM
May-22-2019 08:31 AM
2oldman wrote:jbfoster wrote:Maybe.. 50a is a lot for one battery. You're likely to see a huge voltage drop.
Almost forgot the 650 watt coffee maker to make a cup or two a day. That shouldn't be too much at 600 watts for about 3 minutes a cup.
May-22-2019 07:52 AM
May-22-2019 07:26 AM
May-22-2019 06:55 AM
Airdaile wrote:
You want to look at a battery's reserve capacity rather than amp hours.
May-22-2019 06:29 AM
