Weber Q on Aux LP
iagary
I have an auxiliary LP hose for a gas grill. The grill that came with the camper is of poor quality. I want to use an older Weber Q (smallest one without side tables). Is it as simple as removing the LP regulator from the grill and installing a quick connect fitting to fit the auxiliary LP hose?
9 REPLIES 9
Gene_Ginny
Yes it is that simple. There is a member of the forum that posted some excellent pictures of how he modified his Webber. I can't find the thread ... ๐Ÿ˜ž
Gene and DW Ginny
[purple] 2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363[/purple]
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
iagary
Thanks everyone. I always learn exactly what I need from you all on this forum. Much appreciated!
icanon
I converted mine Q1200 to feed off the 20# tanks and it's very easy.
Loving wife and 2 beautiful daughters.
Chocolate Lab, Lily
2014 Dodge Ram Laramie Hemi 5.7 with 3.92
2014 Dutchmen Kodiak 290BHSL
ProPride 3P Hitch
Progressive Industries EMS-PT30C
Love my Weber Q1200
Me a Happy man on retirement!!!
Shadow_Catcher
Can be done, one source Conversion kit
johntank
Question; where is the control knob for the grill? If it is built in with the regulator, all I can say is good luck with your project.
Joe417
I haven't run one on my TC, but others on the forum have said they used the grill regulator fed from the RV regulated connection and it worked fine. You don't have to remove it. All they bought was an adapter for the quick disconnect on the RV.
That allowed them to move between the RV supply and an unregulated bottle supply without changing the hose.
I didn't find the posts concerning the subject.
Joe and Evelyn
geneeich
Need to use Q grill on high pressure side of tank. The Q already has a regulator. I bought an adapter at Amazon to put on trailer tank and connect a 12'hose. If you find a way to by pass the Q regulator that may work with trailer regulated propane.
2015 F-250 Crew Cab Long Bed Diesel
2016 Rockwood 2906WS Travel Trailer
iagary
Yeah, but since I have the auxiliary hose that is on the regulated side, It would be much more convenient just to use that. Thanks for the reply.
rexlion
I have a Q100. I unscrewed the mini bottle and attached it to a 20 lb tank via one of the common adapter hoses (available at WM and all over).
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
