Here is what I have run into with the WFCO on this non going into boost issue.
Part of the problem is wiring within the camper. A long run on no. 6 awg across a 25 to 18 ft run between the battery and the converter limits the converter from going into boost and it also limits the amps from the way the converter senses the battery.
In my case, the factory installed a 30 amp self resetting breaker in that same main feed line to protect the battery, wire etc. They know the converter will never be passing anywhere near the 30 amp breaker limit back to the battery in charge mode. The WFCO's in this setup has real issues going into boost.
My guess is, you may only be getting 15 to 20 amps from the converter to the battery regardless being in boost at 14.4 or standard charge at 13.6 volts. That is what I measured on mine while boondocking.
I did change out my converter from a prior 2 stage American Enterprises to a Progressive Dynamics and it has no issues going into boost, I can even use the wizard and force the modes. BUT, that same small wire that long is still limiting the charge amps even in boost mode.
In order to get the amps up, one needs to move a good power converter real close to the battery and used really large short cables. Then the converter can sense the battery resistance better and pump up the amps also.
It seems that maybe, the standard RV setup with a 55 amp or 60 amp power converter is setup to allow, approx. 20 amps to charge the battery while the rest of the 35 to 40 amps is running the camper. That smaller wire setup is making that happen on a long camper.
Hope this helps
John
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10 RA, 21,000 GCWR, 11,000 GVWR, upgraded 2 1/2" Towbeast Receiver. Hitched with a 1,700# Reese HP WD, HP Dual Cam to a 2004 Sunline Solaris T310R travel trailer.
