โJul-09-2015 11:17 PM
โJul-10-2015 08:12 PM
โJul-10-2015 03:14 PM
โJul-10-2015 03:02 PM
โJul-10-2015 01:34 PM
smkettner wrote:
^^^ what is missing is the controller set point assuming PWM.
โJul-10-2015 01:10 PM
โJul-10-2015 12:51 PM
MrWizard wrote:
right now the sun is NOT quite STC
i am under partial shade, sun only on front panels
other panels fully or partly shaded (leafy shade NOT deep shade)
i just measured 18.88 amps @ 14.31v as controller output
input voltage measured at 15.45v
we don't know how the IP curves were created, but unless it was on a known calibrated load that we can compare too (which is not stated)
I think it was probably measured on a short circuit or directly connected to a battery
โJul-10-2015 12:38 PM
BFL13 wrote:Yes exactly. Amps increase to Isc causing the voltage drop along the panel IV curve.
With PWM, panel voltage = battery voltage plus line loss, so howinheck can the controller input be at 16v?
โJul-10-2015 12:24 PM
โJul-10-2015 12:15 PM
โJul-10-2015 11:41 AM
โJul-10-2015 11:22 AM
โJul-10-2015 11:14 AM
โJul-10-2015 10:47 AM
