Winegard RoadTrip
Eagle1951
Have a roof mounted satellite tv antenna. It moves and search satellite but motors appear to continue running when parked and tv broadcasting.
2 REPLIES 2
accsys
When we had a Roadtrip (we have since installed a Trav'ler), once I had a good signal on the TV, I turned the Roadtrip off so it wouldn't start searching again.
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
lryrob9301
How long are you allowing the antenna to finish it's reception fine tuning? It is not unusual for a Winegard Roadtrip to take 5 to 10 minutes to fine tune its positioning and stop searching after acquiring and locking on a sat signal.
