โMay-22-2016 07:17 PM
โMay-23-2016 11:28 AM
โMay-23-2016 10:57 AM
Kayteg1 wrote:
Other issue will be allowable charging current for the batteries.
Rule of thumb would be about 20 amp, so 75amp might be killing current.
โMay-23-2016 10:41 AM
โMay-23-2016 07:44 AM
Can I use the frame as the negative path in place of the battery to charger cable? Is this considered beneficial/safe/recommended/worth the effort ... etc, etc.?Yes, you can and the frame will have less resistance in most cases. The downside is that you'll also have to establish a ground to frame from the battery. Also, you'll now have two additional ground connections. For most, that isn't an issue but for some purists it is additional failure point.
โMay-23-2016 07:17 AM
โMay-23-2016 06:00 AM
grizzzman wrote:johnm1 wrote:
grizzzman - would you please explain as I don't understand what you mean by "the numbers don't lie".
Sure look at my earlier post. I crunched the voltage drop number's for you. Have a look.
โMay-23-2016 05:58 AM
โMay-23-2016 05:39 AM
โMay-23-2016 05:37 AM
โMay-23-2016 05:09 AM
johnm1 wrote:
Ok, a lot of the ideas and thoughts never occurred to me. Like I didn't know I could just add another run of 6 gauge wire. I think that'd be fairly easy to do. Can I run the battery neg to the frame with larger (or doubled) wire and use that as the ground to the charger? Would I gain anything by doing that?
I forgot to add our typical camping modes. It's a mix of dry camping (can't really call it boondocking since we're in a campground with amenities - just no power to hook into) and campgrounds with power. We can be at either for a short 2 day weekend but up to 2+ weeks at a time (this is where the gen comes into play). Lots of shade so solar isn't really viable, but I'm going to really pay attention this year at the available sun spots for a portable panel setup. We are very frugal with power usage. All LED lights, have a portable propane heater to take the chill off before bed and after waking up (not while sleeping). And, when we get home, the RV gets plugged into a 30A outlet and charged until we go out again.
Lastly, I went with the 75A charger because, that's what Randy (at BestConvertor) recommended based upon what I told him which includes that I may add 2 more 6v gc batteries (for a total of 4).
Thanks all!
โMay-23-2016 05:08 AM
rjxj wrote:
I have about the same distance to my batteries and went to 4 g wire. I'm not sure you could get 2 g in the lug but they do make adapters. You say "get the most efficiency" so you probably mean that you are off the cord a lot boondocking? If you are plugged in a lot and there is a little more voltage drop than you might like it wont matter over time. If running a generator only than voltage drop is very important. Did you do a voltage check at the converter terminals and at the battery terminals.
โMay-23-2016 04:52 AM
โMay-23-2016 04:22 AM
โMay-22-2016 10:56 PM
Porsche or Country Coach!
โMay-22-2016 08:50 PM
Kayteg1 wrote:
What Instructor is quoting apply to household wiring, where there is not much heat allowed.
You might be surprised that on lot of cars starter wire is #6 and carries 400 amp. But then starter is short duty and some heat on the engine is not a problem.
When running #3 wire is always an option, I wold just touch the wires and connectors during charging. Or better yet, get one of those infra-red thermometers. By buying one with laser pointer you will have new toy for the cat as well .
