โJul-27-2016 12:50 PM
โJul-28-2016 01:01 AM
pianotuna wrote:
Hi Almot,
The Tristar units do not let out the magic blue smoke when they over load. They simply clip off the excess. (within reason, of course)
โJul-27-2016 08:49 PM
Naio wrote:
I was thinking that the problem is that they don't get charged correctly if they are not balanced at load time. One gets too much or the other gets too little.Is that wrong?
โJul-27-2016 08:06 PM
N-Trouble wrote:I don't know how you can ignore the calculations made here. The basic physics and math are true for 100 amps or 10 amps and the balanced method is as easy as any other.pianotuna wrote:
Ah but it does matter. The wiring needs to be done so the jars are balanced. See the link posted above and read it.N-Trouble wrote:
12V are wired in parallel so it doesnt really matter which battery you connect +/- to.
In the case of two 12V batteries under realistic loads (not 100A...) the resistance is going to be negligable in real world use to the point you would never perceive a difference in battery performance.
โJul-27-2016 08:05 PM
โJul-27-2016 07:55 PM
โJul-27-2016 07:23 PM
โJul-27-2016 07:13 PM
Colo Native wrote:
it is 45A Mppt and the run is under 3'. it said wire is rated 65 amps
โJul-27-2016 06:10 PM
โJul-27-2016 06:08 PM
โJul-27-2016 06:01 PM
โJul-27-2016 05:45 PM
โJul-27-2016 04:45 PM
scrubjaysnest wrote:
X 3 reference here: battery wiring applies to solar as well as batteries
โJul-27-2016 04:11 PM
Almot wrote:Colo Native wrote:
One more question do you think 6awg is enough to go from controller to battery, I have a lot left.
What is post-controller max current and what is one-way cable length?
โJul-27-2016 04:05 PM
