โNov-20-2018 08:44 AM
โNov-30-2018 01:12 PM
โNov-30-2018 11:01 AM
โNov-28-2018 02:10 PM
โNov-28-2018 01:19 PM
BFL13 wrote:
My problem is the definition of "output voltage"
You have the battery voltage at 12.2v and the charger is set to 14.8v. connect them. Voltage at the charger is now 13.5v and at the battery it is 13.3v with 75 amps on the wires between them.
As this goes on, battery voltage rises with its SOC. So later you see 14.2 at the charger and 14.0 at the battery. You happen to be at the end of Bulk and amps start to taper.
Voltage at the charger a bit later is 14.4 and at the battery it is 14.3 with 45 amps being accepted. (fewer amps so less voltage drop)
Eventually, you are at 14.8 at the charger and at the battery with no amps flowing. all done.
So what do you use for "output voltage" during the Bulk Stage, which is what I care about. ( Once amps taper for the Absorption stage I am home free because VA required from the gen drops off and no more red flashing light)
โNov-28-2018 12:53 PM
MrWizard wrote:I need to do a standard 50-80 recharge and see if the gen has to supply as much to the converter at 50% as it does at 70% SOC.
got it backwards again
at 50%soc the battery will accept more amps and converter will be using MORE power, VA will be higher than when when SOC is 70% and the battery is accepting less amps
UNLESS the bank is so large that it can still accept (converter max amps) at 70%SOC, in which case VA will be up, watts into converter will be up because voltage to battery has risen
what size is the battery bank ?
at point does amps into bank start to drop ?
i know in my case amps drops off long before converter reaches 'set point' voltage, set point voltage is not reached until batteries are almost fully charged
โNov-28-2018 12:35 PM
โNov-28-2018 11:58 AM
โNov-28-2018 11:45 AM
BFL13 wrote:
Why should the converter care how many of its output amps are going to heat and how many are going to raise battery SOC? I am thinking the converter needs the same 120v input power.
OTOH, I still have that problem where it pulls less power when doing its 75 amps while "supplying" than when battery charging. I suppose that is because of less resistance when supplying.
It is also when battery voltage is quite low while being pulled down by the inverter running the MW while the charger helps put amps in at the same time.
โNov-28-2018 11:30 AM
MEXICOWANDERER wrote:
You are not dealing with a fixed resistor. But a reactive electro chemical response.
Look up
Charge
Efficiency
Factor
โNov-28-2018 11:21 AM
โNov-28-2018 11:19 AM
โNov-28-2018 10:44 AM
My problem is that I have not seen VA rising (not enough measuring perhaps) during the Bulk stage. Constant 75 amps while SOC rises from 50 to say 73%. Battery voltage rises all during that time.
So I would be looking at VA vs battery voltage in the Bulk stage. I did see on the Kill-A-Watt how the VA components change. Lower 120v voltage and higher 120v amps to it over time. I want to see what that was all about too vs rising battery voltage over a longer time.
โNov-28-2018 10:10 AM
MrWizard wrote:I am not happy with the idea the converter requires more VA as the battery voltage rises, for instance. I can test for that over a longer recharge time from a lower SOC
Confuse yourself ?
Efficiency changes as the charge SOC progresses, but the converter does not need more VA to deliver 40 amps charge than it does to deliver 75 amps charge
How ever, When I get down to 4 amps charging, pf is like 0.546
But when it's charging above 70 amps PF is like 0.768 I remember seeing 0.796 at one point
Watts in versus battery charging amps always changes as the battery fills up
That's true of all switching supplies, and our converter is a switching supply
โNov-28-2018 09:43 AM
