Yamaha gen fixed, running great again
tealboy
Well, it proved easier than I expected. I did need to pull the fuel tank and remove the electrical panel on the front to get to the carb but that was fast and easy. Pulled the carb and removed both jets, the idle jet had some debris not sure about the high speed main jet but anyway, cleaned everything, put it back together and it runs fantastic. Essentially same job as I had to do on both hondas for the same surging problem.
Thanks to several of your for the help, oldwizard in particular but others too.
1 REPLY 1
theoldwizard1
Great to hear ! Your welcome (messin' with small engines is a hobby of moine)
