Jul-29-2023 08:51 AM
Aug-01-2023 10:24 AM
Cummins12V98 wrote:FishOnOne wrote:Cummins12V98 wrote:FishOnOne wrote:Cummins12V98 wrote:
This BS of fill til it clicks and wait then same is a joke. It takes a bit but you can fill to the top if you want.
I think this method is legit as long as you do it the same way every time.
Haven't you noticed different flows if someone else is filling on your island while you are also?
So you mean to tell me that another pump on the same island pumping fuel at two different locations is why these two Duramax trucks yielded impressive fuel economy results?
WOW, put words into my mouth!!! I never said a word about the results just the method of fueling. Remember reading and comprehension go together. :B
I gave you an example with a question of why it can't be accurate but you chose not to address my statement/question.
Aug-01-2023 09:04 AM
Jul-31-2023 06:10 PM
Jul-31-2023 05:35 PM
Jul-31-2023 12:32 PM
Jul-31-2023 12:18 PM
Jul-31-2023 08:10 AM
Jul-31-2023 07:39 AM
Jul-31-2023 07:21 AM
4x4ord wrote:
The trouble with mpg tests is that they don’t take into account cleaning the DPF. To be accurate the test should start with a clean DPF and end the same way.
Jul-31-2023 03:40 AM
