Aug-06-2022 10:48 AM
Aug-10-2022 01:44 PM
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch • 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") • <\br >Toys:
Aug-10-2022 01:02 PM
Reisender wrote:dodge guy wrote:Reisender wrote:dodge guy wrote:shelbyfv wrote:
Wow. OP posts info useful to other EV owners. The usual goobers jump in with three pages of irrelevant "EVs won't never work." LOL for sure. Kudos to OP for handling the snipes with such grace.
It’s not irrelevant! Let’s see how happy you are traveling 160 miles a day!
F150 Lightning tow test!
I know nothing about the Ford lightning. But when we were crossing the prairies and part of northern Ontario with our EV RV combo a typical day was 500 to 600 kilometres which is pretty much the norm for us. I haven’t watched the ford video. What was the problem?
86 miles per charge towing a 6k lb TT. With a 1 1/2 hour charge time. Not getting very far with a traditional setup!
Wow. Those suckers charge slow. Just looked it up and they only charge at 150 kw. Wonder why they picked that. Probably some tech reason beyond my pay grade. :).
Typical charge time for us is 20 to 30 minutes although at lunch we are usually closer to 40 minutes by the time we eat, walk the chihuahua and so on. We almost always get a charging finished text from the charger before we are finished lunch.
No idea what our max range is although it’s probably around 220 kilometres. Our stops are determined by distance between superchargers which varies. We also use public DC fast charging if it’s convenient. Lotsa variables.
I bet you’ll see ford step up that charging rate in the next year or two. They should be hitting at least 250 kw and shooting for 300 or 350 kw. Our SUV with a battery a third smaller hits 250 kw at a lower state of charge. Should be interesting to watch develop.
Just a guess. Really no idea.
Cheers.
Aug-10-2022 12:59 PM
Aug-10-2022 12:56 PM
Aug-10-2022 08:06 AM
Aug-10-2022 07:46 AM
wa8yxm wrote:Fisherman wrote:
It's a good thing we don't need adapters to put energy in our gas or diesel tanks. Nothing worse than having proprietary plugs and receptacles to achieve the goal of charging batteries. Similar to all the different versions of plugs for electronic gadgets.
Well. you are mistaken.. I've seen adapters for just that use. (Though they are rare these days) In the old days some cars could only use one of.. generally. 3 pumps. or else they had to use an adapter.
There are other considerations as well. Today I can not use one of three gasoline pumps with my Ride.. (The other two work fine) And it's best not to try and adapt. (I might get away with it for say a half mile but I truly don't wish to try it)
And this is a high-gasoline-usage month for me.
Aug-10-2022 07:31 AM
Aug-09-2022 03:26 PM
Aug-09-2022 03:05 PM
Aug-09-2022 12:34 PM
dedmiston wrote:
Thanks for the helpful info, Reisender.
Sorry that the EV threads so often go off the tracks.
Aug-09-2022 12:30 PM
Aug-09-2022 11:45 AM
Aug-09-2022 11:22 AM
Aug-09-2022 06:54 AM
