Your biggest concerns will be all appliances work, leaks causing wood rot, roof condition. At that age the roof is likely toast, possibly water leaks and frame rot, plus good chances the refer is DOA or on it's last legs. Roof replacement alone could cost you more than the trailer is worth. New refer is easily a thousand dollars. Wood rot could make it a total wreck good knot for scrap.
