2003 Chevrolet Tahoe heat/ac fan not working.
jbres
So my 2003 Chevrolet Tahoe with 154,000 miles has issue with blowing heat and or a/c. For awhile, its only worked on speeds 3-5. Now, only working on speed 5. 1-4, not working at all. Is this an issue with my blower motor resistor? Is this easy to access on the 2003 Tahoe?
Do I access it on passenger side below the glove box area?
Thanks!
8 REPLIES 8
jbres
thanks for all the advice! got a used blower resistor at junkyard today for $12.00, and works like new! so easy to fix!
_40Fan
Replace the blower motor too! It is the high resistance of the blower that causes early resistor failures.
2013 Arctic Fox 22GQ
2011 Ram 2500 CC LB CTD G56 3.42 Mineral Gray
kw_00
Fan resistor, get it from any parts store. Very common issue, so easy to fix!
A truck, a camper, a few toys, but most importantly a wonderful family.
Campfire_Time
I concur on this being the blower motor resistor. It's probably about $12. It's usually behind the heater box but not too hard to get to. As said, search Google and you'll find a youtube video.
Chuck D.
“Adventure is just bad planning.” - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
closurdo
Had the same problem on my '03 Silverado a while back, was the fan resistor located in the heater box on the passenger side. Plenty of videos on Youtube on how to change it out and I think it was only three screws to remove it. The part was available at my local auto-parts store for around $25.00
2003 Silverado 2500hd Duramax
1998 Sunnybrook 26cks
Equal-i-zer Hitch
MinnCamper
Change out the fan resister. I've done it a bunch of times. Google it real easy fix.
AJBert
On my 2000 Chevy Blazer I only have 4 speeds. However, 1-3 get their power through a fuses and 4 comes from the relay. You might want to look at your fuses.
srt20
The switch in the dash. Common issue on that era GMs.
