2004 Fleetwood/Coleman Tacoma Popup Bolt Question
elkrott
I have a 2004 Fleetwood Tacoma popup and I noticed that the nuts on the bolts that attach the 4 side channels that have the wires and pullies in them are tight on the bolt but not snugged tight to the bracket that is attached to the roof. I have a feeling they should be loose so the side channels can float as your raising or lowering the roof am I correct or should they be tight.
Any help greatly appreciated.
Ellis Krott
0 REPLIES 0
