2005 Starcraft Aruba 28RLS
agillings
I own a 2005 Starcraft Aruba, I asked a question of StarCraft Customer Service, "Is there a drawing of my framing of the trailer"?
Their response was " there is no frame it is fiberglass and is just glued together" I kind of find that hard to believe! Can anyone assist me with this?
Thanks
Art
3 REPLIES 3
agillings
Good News!
Finally received all drawings for the 2005 StarCraft Aruba 28RLS including a few extra's. Is there some place on this site where they can be stored so other people can have access to them? They are in PDF format
Thanks
Art
agillings
Thanks, I contacted them again and they said they do not have any drawings, hard to believe! Do you by any chance have those drawings or is there anyone on this forum that might have them. Thanks in advanced if you do!
Thanks
Art
handye9
They do have a frame. I had an 04 Aruba, that I wanted to add another roof vent. I contacted Starcraft and they sent me drawings that showed where the roof framing was located, they didn't have drawings on electrical wiring. Apparently, their customer service has gone down a bit.
There are trim pieces on your ceiling. They hide the seams between ceiling panels, and, they line up with a framing member. The roof structure on my 04, had trusses, 16" on center.
Walls may be a different story.
Double check with a stud finder, before you make any cuts.
When I cut for a new roof vent, I used a zip saw, with blade depth set at the thickness of the paneling. I did find wires, but, only the ceiling panel was cut, and there was enough slack to move the wires out of the way.
18 Nissan Titan XD
12 Flagstaff 831FKBSS
Wife and I
Retired Navy Master Chief (retired since 1995)
