2011 Amerilite 23BW Weight
surgtech56
We have a 2011 Amerilite 23BW and trying to figure out the weight of it. If a V6 can pull it, like a Chevrolet Canyon, Dodge Durango, mini-van?
5 REPLIES 5
Swell1
Looking at the specs on this trailer the GVRW is 6670lbs. Now you'll have to see what the vehicle can haul.
2017 SportTrek 271 VRB
2016 F150 Eco boost with max tow package
surgtech56
We're having to either downsize a vehicle or the camper
SoundGuy
Since you already have this trailer wouldn't the obvious answer be to load it ready to camp and go weigh it? :R
2012 Silverado 1500 Crew Cab
MFL
Nomad II
Nomad II
You have an estimate on the dry wt, now look at the sticker on driver's side front of trailer for actual GVWR. This is the maximum the trailer can weigh. You will likely be somewhere in between the numbers, when loaded to camp. I'm thinking it may be a big load for vehicles mentioned, unless just using/towing close to home.
Jerry
downtheroad
It's got a dry weight of 4200+ lbs. (which is meaningless)
Maybe you can get an idea from this...Hope this helps some anyway.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
