2013 Ford 350 diesel auxilary tank plumbing ??
ivbinconned
Can a person run a direct line from the truck box auxiliary tank to the smaller breathing hose close to the filling location and leave a valve open on that hose with out any leaking when the factory tank is full??
I do this with an 06 Ram with no problem.
Ram and 34 ft Cedar Creek
18 REPLIES 18
dave17352
If you leave the fuel flowing into the breather hole there will be no breather hole. I don't think that would be a good idea. I am sure they would have suggested that if it was a option.
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
ivbinconned
Lawn. That is a "gravity flow control valve" isnt it??
It prevents over filling of the truck tank i beleave. I want to know if i can just "T" into the breather or filler hose with out over filling.
lawnspecialties
This is what we used.
Tank Plumbing
lawnspecialties
My RDS tank runs straight into the filler tube. When the cap is closed, it fulls up completely but nothing runs out. Just don't open the cap! I speak from dumb experience.
Make sure you put a small ball valve or something on there to turn off the fuel if you ever need to. When I have mine parked for extended periods of time, I turn the fuel off. But I had my old 2011 F450 with this set-up and my new 2015 F350 is done the same way.
By the way. My Ford dealer did the installs and they recommended it this way.
