2013 ford explorer
dennych1
Does anybody ow with a 2013 explorer with tow package. If so how much weight and what size camper?
Thanks
3 REPLIES 3
RWDIII
dennych1 wrote:
Looking at passport 171exp 3600lbs dry.
my wifes 2013 explorer is AWD and came with tow pac
Payload is 1436 lbs and will tow 5000 with WD,however tongue wt is only
500 lbs so you should be ok under 4000 lb
OLD 2006 F150 4wd 7200gvw,Lt275-65-18,Scan Guage,Garmin,flowmaster,load levelers,Firestone work rites Bronco 800
NEW 2015 F250 Scab 4wd 10000 gvw, 6.2 Scan guage,Garmin,work rites,3200 lb load,1800lb Palomino Backpack SS1200
dennych1
bikendan
you can go the the 2013 Ford Towing Guide to find the towing specs.
from what i know, the new Gen Explorers have an absolute max of 5000lbs. IF it has the factory tow package.
don't know what their payload capacities are.
