2014, redo, foam in Dinnette Cushions
sleepy
During our 2014 trip I found that my bones were quickly pushing through the foam on the dinnette seats... to the point that my rear end hurt.
I am more than 50 pounds lighter than I was just a few years ago.... it had to be worn out foam.
When we got home from our coastal trip from Lake Charles area to South Padre Island I made an upgrade my priority.
I'm pretty sure that a few of you might benifit by upgrading yours.
2003 Lance 1161,/slideout/AGM batteries/255W Solar/propane generator/Sat dish/2 Fantastic Fans/AC/winter pkg
AirFoil, Trimetric, LED lights, Platcat vent heat
2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
58 REPLIES 58
sleepy
sleepy
Starting to reassemble inside the old covers...
sleepy
sleepy
I didn't waste much...
sleepy
Did I say that it is a big job?
sleepy
The last one... the glue became tacky and I got it assembled
sleepy
You will need...
especially if you are going to do a composite build up like I have here
sleepy
The spray glue has different widths to chose from...
sleepy
I am cutting it close... the glue doesn't go as far as I thought.... it ran out ant the exact best possible time.... luck is getting better...
sleepy
One to go...
sleepy
At this point I'm feeling better about this project... Janet is sleeping in the recliner.... recovering from surgery... I can see her through the picture window... getting stuff done... waiting for the glue fumes to off gas...
sleepy
I have 4 cushions... and they'll be at different stages in the process... one may get finished while another is just getting started..
the pictures were of secondary importsnce st the ime... but you are getting them about like I was working.
I'll have some trimming of the white "comfort" strips
sleepy
this is where I sprat glued the surfaces of the foam... after it gets tacky I'll put the pieced together....
The brown under the foam is cardboard... to keep the glue off of the porch.
the glue has a srong,smell and is very flamable.... do it outside
sleepy
I had the supplier make any cuts that I could get them to understand... then I did the detail cuts with an electric carving knife.... that I borrowed from a friend
sleepy
The new foam...
Unpacked and allowed to expand to normal.... it was very compressed when it came.
