2016 Highlander brake controller question
Steve_911
Does anyone know if a 2016 Toyota Highlander with a factory tow pkg. has a wiring plug-in under the dash for a brake controller?
Thanks,
Steve
16 REPLIES 16
Bumpyroad
found the invoice for my 2011 Highlander. towing package included:
heavy duty radiator with engine oil cooler, 200 watt fan coupling transmission oil cooler with water cooler, 150 amp alternator and prewired harness.
did NOT include receiver and required one more wire to be run to rear for brake controller.
so nothing really related to "strength", just longevity.
bumpy
Steve_911
I agree cool. The factory "tow pkg." should include the hitch and the combo plugins like the Tundra and Tacoma.
I will be pulling a small travel trailer weighing about 3k empty, and likely 4K with all my junk.
westend
It's been awhile but IIRC, there is a "t" in the back of the Highlander to accommodate trailer wiring. I'd check the owner's manual.
'03 F-250 4x4 CC
Bumpyroad
coolbreeze01 wrote:
My HL has the OE receiver and 4-prong, but pretty much worthless. 7-prong should be OE if they want to call it a trailer package.
that depends on what type of trailer they are talking about. I have towed boat trailers with the 4 prong connector for many years. with the RF brake control a 4 prong might work also.
bumpy
coolbreeze01
2008 Ram 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2014 Sandsport 26FBSL
Steve_911
I agree. That's why sites this one is so important to people like me who are rv beginners.
Very helpful....
SoundGuy
Steve 911 wrote:
recently my Toyota dealer install a hitch appropriate to make the Highlander's tow rating, including a 4 pin plugin and a 7 pin plugin. I still need to run a line from the battery to that 7 pin plugin, and install a brake controller..
Which demonstrates how little vehicle dealers know about towing recreational trailers and what's required for doing so, for if they did they'd have installed that charge line while they were at it. :S You won't be towing without a brake controller either so why wasn't that done as well? :h Let's hope nothing else was missed. :W
2012 Silverado 1500 Crew Cab
Steve_911
Bumpyroad
Steve 911 wrote:
Im considering getting a Prodigy RF. Just not sure about reliability...
do you have the tail/brake light device already installed? if you do the RF would make life a little easier. I almost went that route when I was having a heck of a time finding the hookup behind the left kick panel.
bumpy
Steve_911
I know..I need to poop or get off the pot and make a decision...lol
SoundGuy
We've already been through this with you in this recent thread ... not much more that can be said. :R
Steve_911
Bumpyroad
My 2011 required them to run an additional wire which they hadn't counted on in their estimate. ๐Ÿ™‚
now be prepared to be sassed at by those who think you need a F-550 to tow a 17 ft TT.
bumpy
Steve_911
Thanks. I couldn't find any info from Toyota sites.
