2020 PSD owner compares it to his 2019 PSD towing 18K
ShinerBock
This just came across my recommended videos on YouTube after watching Fish's 2020 7.3L video. He gives a pretty honest (and long) comparison for this who have a 2017-2019 and are thinking about switching. He also has a Banks iDash so you can see some of the temps although I believe the pyro-meter for the EGT's on the PSD is after turbo just like the CTD is which is about 300-400F cooler than pre-turbo numbers where most aftermarket pyro's are.
2020 FORD SUPERDUTY 10 SPEED TOWING 18,000lbs!
2014 Ram 2500 6.7L CTD
2016 BMW 2.0L diesel (work and back car)
2023 Jeep Wrangler Rubicon 3.0L Ecodiesel
Highland Ridge Silverstar 378RBS
89 REPLIES 89
Cummins12V98
FISH I pictured you as a Manly Man that did his own maintenance???
"The Aisin would have been to the shop for service 3 times during that period."
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
4x4ord wrote:
Cummins12V98 wrote:
4x4ord wrote:
Ford requires the transmission fluid be changed every 150,000 miles. How often is the fluid to be changed in the Aisin?
30k fluid then 60k filter and fluid. Iโ€™m thinking this is to do with the use these AISINโ€™s see in Medium Duty applications.
I will say there is no way in HE11 I wold go 150k towing what I do with a new Ford.
You gotta get a Ford. There is no way I'll keep my truck long enough to require the tranny fluid to be changed. I change the engine oil every 25k km and add fuel and windshield washer fluid as needed. That has been it for maintenance other than tires.
If I were in the market for a Gasser It could be a Ford, Diesel......NO!!!
FishOnOne
I changed my transmission fluid around 100k miles. The Aisin would have been to the shop for service 3 times during that period. My 05 Super Duty required transmission service every 30k miles.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
4x4ord
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
FishOnOne
ShinerBock wrote:
In regards to the exhaust brake, I am not surprised that he says that the Cummins exhaust brake is better than even his new 2020 though. It appears that he is not the only one to think that.
I was watching his videos a while back when he was evaluating a Ram HD truck but ultimately he felt the new Ford was overall a better performing truck like others have reported.
FishOnOne
ShinerBock wrote:
IdaD wrote:
FishOnOne wrote:
blofgren wrote:
Certainly a nice truck, but none of those "big" hills he was climbing looked all that big to me. There are several mountain passes here in BC that would have that truck working much harder! :B
You can't tell the magnitude of a hill from a video.
A Texan wouldn't be my first choice for an opinion on the topic.
ROFL!!! Ha ha ha. So true. Many here think the hill country is steep.
I never said the hill country is steep nor do I recall anyone here saying that. I've seen several videos where someone is pulling 7-8% grade and from the video the road literally looks flat and even the driver emphasis that you can't tell how steep the road is via the video.
Cummins12V98
ShinerBock
Cummins12V98
Dang, that even hurt me!
IdaD
2015 Cummins Ram 4wd CC/SB
ShinerBock
4x4ord
B&W Companion
ShinerBock
According to the signs, this is the route he took and turned back around. Not sure if anyone has a way to find the grade on the stretch of highway.
Nova Scotia 103
FishOnOne
blofgren
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
