โDec-01-2020 12:18 PM
โDec-16-2020 06:23 AM
Cummins12V98 wrote:
"I mean whatโs your opinion about the Cummins thatโs 370/850? Iโm thinking with 4.10โs that combo will be just awesome for loads under 25k."
My 15 DRW/AISIN is a measly 385/865 and it moves my combined 35k double tow load just fine all across the West Coast. Trans nor engine ever gets hot even in 100 degree weather pulling long 6% grades.
โDec-16-2020 04:19 AM
โDec-15-2020 07:52 PM
4x4ord wrote:
I donโt blame you, however pump failures are less common in Canada. I think our fuel must provide a little better lubricity. I think Iโll buy what I want based on price and take my chances on the pump. In the unlikely event that my pump fails Iโll hope itโs cornered under warranty,
โDec-15-2020 10:47 AM
โDec-15-2020 10:20 AM
ShinerBock wrote:
I will say that the Denso HP3 and HP4 pumps are not without their flaws either. We have had some failures on them as well in the Hino(Toyota) medium duty diesel trucks. There are even a few TSB's out for them. The reason why most probably don't here about them is because Denso does not have that big of a market share especially in the personal vehicle market. Even on the commercial side, diesels powered by Denso fuel systems is very small.
I think people need to understand that these pumps are pumping at very high pressures. Just as with horsepower, the higher you go, the likelihood of component failure increases as well. For all you wanting and bragging about more stock short burst power, this is what you get because the manufacturers have to increase pressure every time they have a major power increase in order to stay emissions legal. You can't have your cake and eat it too. As with VG turbos and other components, you are starting to sacrifice reliability for the pursuit of more power on engines that also have to meet emissions.
Hence the reason why I would rather the engine makes have lower power, but use more reliable parts. I can easily add power after the fact that will make the truck more reliable by ditching things like electronically controlled VG turbos and so on that are less reliable than their mechanical counterparts.
โDec-15-2020 08:10 AM
Cummins12V98 wrote:
"however pump failures are less common in Canada"
What do you base that on?
โDec-15-2020 07:54 AM
โDec-15-2020 07:37 AM
blofgren wrote:
If I were shopping for a new diesel truck right now it would almost certainly be a GM because they switched to a Denso pump.
โDec-15-2020 07:28 AM
โDec-15-2020 07:14 AM
โDec-14-2020 10:19 PM
โDec-14-2020 05:02 PM
4x4ord wrote:
Does Cummins use the same pump as Powerstroke cuz I just read that the Cummins has a 29000 psi fuel delivery system where as Ford claims they went to 36000 psi for 2020? I think both use the Bosch 4.2. How does that work?
Edit: Upon doing further google searches I found evidence of a CP4.2 pump failure in a 2020 Ford. Even if the pump has been changed for 2020 it sounds as though itโs still a POS. It seems almost unbelievable that Ford would stick with Bosch even if the number of failures are rare the damage these failing pumps do to the Powerstrokes reputation has got to be costly to Ford.
โDec-14-2020 10:31 AM
ford truck guy wrote:MFL wrote:ford truck guy wrote:
WOW.....
almost 15 pages of this banter back and forth !:S
Lots of banter for sure! With most forum sections being slow, tow vehicles still keeps somewhat active.
I still read much of this back/forth, and have to say, that Shiner has a lot of knowledge to share, and shares it in a respectable way. Just my observation, not taking anyone's side of the issues.
Jerry
TRUE Jerry,
I have always looked at BOTH shiner and 4ford, and MANY others here as A lot more knowledgeable than I ..
It IS interesting to read each post...
โDec-14-2020 09:21 AM
WOW.....
Jerry
TRUE Jerry,
I have always looked at BOTH shiner and 4ord, and MANY others here as A lot more knowledgeable than I ..
โDec-14-2020 09:17 AM
WOW.....
Jerry
